Hi
I got most of my 99 S70 T5 suspension, as we are ready to change my mechanic buddy says it needs new ball joints, question is, do they come separate or you have no other choice but to buy the whole control arm, if so, which one is the best to get???
Im also in need of the swaybar bushings, I called a local shop and they say they only come with the sway bar...who has them? And urethane I would say is better?
Thanks once more for the help
Sway bar bushings 850/S70
Front Swaybar Diameter, P80 Volvos
elchopperfreak
- Year and Model: S70 T5 1999
JRL
- Year and Model: Several
- Been thanked: 16 times
Buy the entire control arm, and buy VOLVO OEM ONLY
There are no sway bar bushings TO buy, your man is correct, they are a part of the factory sway bars
elchopperfreak
Thanks JRL
So theres no way to solve the sway bar, unless I buy a new whole sway bar?? Ouchhhh
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
You can buy just the bushings via cheap aftermarket parts, but it looks like a real PITA to install them anyway.
http://volvospeed.com/vs_forum/topic/14 ... msearch__1
I know I've seen other threads at VS about it; try a Google engine search on that site perhaps. I have the link bookmarked at work, but take a look at their "how to search" thread and try that.
'98 S70 T5
2016 Chevy Cruze Premier
elchopperfreak
VS is volvospeed forum? What is the aprox price on a sway bar.. Seems insane to get a new one, plus ship it to PR for a couple bushings??
Thanks
Thanks
elchopperfreak
Found this, quik link to make things easier if anyone is following this thread
https://www.matthewsvolvosite.com/forums ... =1&t=29384
Another link..
https://www.matthewsvolvosite.com/forums ... 9&p=130397
Another link..
elchopperfreak
elchopperfreak
Now, this is a mission, I will look for the different bushings thanks to the measurements given by another forum member.
This is the plan, I will take off the sway bar from my donor 855 (should be fairly similar, if not the same) and will go at it, lets see how much work, once I find some suitable bushings will it really take..
Maybe Ill do a How To...
Seems kinda lame spending 300 bucks on a sway bar, when all you need is a $20 buck bushings at the most.
- Has thanked: 311 times
- Been thanked: 817 times
You can tell the diameter of the front sway bar based on the color of the paint splotch, located in the middle of the bar:
front sway bar part #s, sizes, paint splotch colors:
9173982 O.Dia 20 mm (marked red)
9173983 O.Dia 21 mm (marked yellow)
9173471 O.Dia 21.5 mm (marked yellow/blue)
papi just get the energy suspension bushings they will probably go for 20 to 25 bucks just get the correct size mine are 20mm pita to get out after rusted to the bar but got old out and new in and car handled better with bushings and ipd sway bar links
- 1909 Views
Last post by Legofan
- 1162 Views
Last post by Botbasher
- 5328 Views
Last post by precopster
- 1146 Views
Last post by oragex
- 454 Views
