how to replace wiper motor on a volvo 740 turbo 1990
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
kingsorder
Year and Model: 1990 740 turbo
Post by kingsorder »
any help wii be greatful . i dont have the extra cash for a tech to swap it out for me , so i have do do the job myself . already got the replacement parts , just need to know the steps to re:re it
yhkan;lsad
:idea:
jimmy57
Been thanked: 320 times
Post by jimmy57 »
remove wiper arms by lifting covers at base of arm and undoing the nuts. Lift arm and wiggle it and it will come off the shaft.
The vent slotted panel the wiper arm shafts pass though covers the wiper motor. If you look on both outboard ends at lower front edge you will see the bolts that have to be removed. Remove those and lift the forward edge and pull straight forward for panel to slip out. There are pins in the cowl and the panel sides have slots that go over the pins. You have to pull the panel forward to the point it almost hits the hood hinges for the pins to be cleared. Now you lift out panel and you will see the wiper motor on the frame. Remove as an assembly and the wiper motor will come off the frame and there is one nut to remove for the linkage arm to come off.
kingsorder
thanks you very much for your time and help
