Panels under s80
Everything on the Volvo S80. Sometimes called an "executive car", the S80 was Volvo's top-of-the-line passenger car. P2 platform.
PPiazza
Year and Model: S80, 2001
Panels under s80
Post by PPiazza »
I noticed a long skinny panel hanging down under my 2001 S80. When I investigated there is a hose above this panel. Does anybody have a diagram of the different panels under a S80 and how they mount, I want to attempt to fix this tonight.
jimmy57
Been thanked: 320 times
Post by jimmy57 »
That is a cover with channels in it to hold fuel lines and fuel vapor lines up under car. The imprint of where it has been should be clearly visible. The cover is held up by plastic screw buttons things that go onto coarse threaded studs that are on underside of floor. The lines at front should still be in the panel in their correct places to use as guide for where you should snap them back into place where it has fallen.
