Emission Sensors stuck in "Not Ready" mode
fjcsr
Year and Model: '97 850 T5
Post by fjcsr »
Having a darn tough time in getting my '97 850 T-5 ready for emissions test. Using a Scanner - the following sensors will not report back as "ready", even after 500+ miles of driving. The sensors that are not cooperating are: CAT, O2S, EVA. :x
Here is what has been done - entire PCV system replaced (That took care of the P0172 code). A new front O2 sensor (bosch) took care of the P0133 code. After the replacement of the front 02 sensor and multiple resets via scanner and hard resets via removing battery cable and letting it sit for a day - the 3 sensors mentioned above will just not report back as ready. I only need one of the three to cooperate since with a '97, 2 not readys are OK for emission testing. I have followed the many write-ups on the driving procedure to "train" sensors. Extension cables in place per the TSB for the O2 sensors.
Here is what the car is doing now: stuck in OL status with occasional CL-Fault being displayed. Front O2 reading is within range, MAP readings (lbs/min) vary from 0.700 (at Idle) to 10.0+ WOT. STFT & LTFT vary when car is out of OL mode. NO CODES PENDING or DISPLAYED.
Can the rear O2 sensor be causing my emission status and OL issues?!?!?!?!
And to top it off - just learned that in VA at least, now my '97 has to be dyno'd as well as ODBII readings for emission. Im not too worried about the dyno tho'......
'97 850 T5, 282K miles and counting.... everyone of them driven by me....
Choguy03
Year and Model: S40, 2000
Post by Choguy03 »
Could be completly different on a Volvo, but my dad was having the same problem on a Dodge Stratus. A mechanic told him to replace the thermostat. If it is sticking open or not letting the engine get hot enough you will not be able to get your car to run through all the systems. Like I said, it could have nothing to do with it, but for a $10 fix it might be worth taking a shot. Keep us posted.
jimmy57
Has thanked: 5 times
Been thanked: 322 times
Post by jimmy57 »
The system is very picky that the sequence for an OBD-II readiness proving drive be done correctly.
Follow this:
http://apps.volvocars.us/ownersdocs/200 ... ection.pdf
And it must be done twice.
The car may still not clear all of them but it should pass with two not being shown as ready.
fjcsr
Post by fjcsr »
jimmy57 wrote:The system is very picky that the sequence for an OBD-II readiness proving drive be done correctly.
Follow this:
Thanks - Its great to see the drive cycle laid out by Volvo. There are many other posts on here and other forums that have transcribed this procedure.
I would say that I believe that I have been through the cycle at least 3 times now.... and those pesky sensors are still not ready....
fjcsr
Post by fjcsr »
so we are at 600 miles and still the O2, CAT and EVA sensors are showing ?not ready". *Sigh*
OK so I could see where if the rear O2 is bad then the O2 and CAT may act like tis - but the EVA(P)?!?!?
I tried the "cold soak" procedure that seems to work on Fords - to no avail.
Anyone?????
Volvos rock3
Year and Model: v70xc, 2002
Post by Volvos rock3 »
In the three years we owned our 96 850, they were never ready. Endless drivetrace cycles, etc. In PA the odo did not work so it "was" driven less than 5k yearly...exempt. You may have to get a waiver from the DMV, as they may never reset...
1996 850 GLT sdn (deceased)
2002 V70XC 118k
2009 S80 3.2 37k
1998 Chevrolet K1500 84k
1965 Pontiac Lemans convt
2009 Chevrolet Tahoe PPV 2x (work)
tjts1
Year and Model: 96 855 NA 5 speed
Been thanked: 4 times
Post by tjts1 »
Print this out and show 'appendix D' to the person smogging your car.
http://www.epa.gov/OMS/regs/im/obd/r01015.pdf
APPENDIX D
Manufacturers Known to Have OBD Readiness Issues
1996 Volvo 850 Turbo - Vehicles will clear readiness at key-off. There is no reprogramming
available for this line of vehicles. These vehicles should be scanned for MIL illumination
without regard to readiness status.
Volvo Technical Service Bulletin #SB 2-23-0056.
1996-98 Volvo vehicles (excluding 850 Turbo) - These vehicles may have a high degree of
“Not Ready”for catalyst and evaporative monitors due to a “trip based” design. Volvo has
provided driving cycles in its service information to allow monitors to operate. These
vehicles should be treated as other non-problematic vehicles.
Ambitious but rubbish
fjcsr
Post by fjcsr »
tjts1 wrote:Print this out and show 'appendix D' to the person smogging your car.
APPENDIX D
The way I read this my 1997 850 Turbo would be excluded from either of these exceptions. Im at getting close to 800 miles on the car with 3 not readys still have not reported back.
Is there anyway to "force" a sensor to report? I read somewhere that the dealer may be able to do this?!?!?!
tjts1
Post by tjts1 »
fjcsr wrote:
tjts1 wrote: The way I read this my 1997 850 Turbo would be excluded from either of these exceptions. Im at getting close to 800 miles on the car with 3 not readys still have not reported back.
Your 1997 is a T5 not Turbo. 1996 was the last year for the '850 Turbo' model name.
fjcsr
Post by fjcsr »
Its worth a shot!!!
I would still love to know why at 285k miles the sensors just stopped reporting back......
