'96 2.0L turbo low boost compared to '94?
christhekiwi
Year and Model: 850 Turbo X 2
Post by christhekiwi »
I have a 1996 2.0L turbo and a 1994 2.4L turbo. As you would expect these are quite different cars to drive. The main difference is torque off the line with the '94 pulling like a trooper.
I have noticed that the little turbo boost gauge on the '94 normally sits on about half way once running, where as the '96 sits way down near the baseline.
Is this normal or adjustable? The '96 is a bit of a slug off the line in comparison.
P.S While doing the TB on this car i found both cam gears off by a tooth so i'm wondering if someone has been playing with the wasteg-ate or TCV too?
Any suggestions?
Marcobrick
Year and Model: 2003 V70T5
Has thanked: 3 times
Post by Marcobrick »
Are you talking about a 2.3 turbo? The 2.4's don't have boost gauges. By "halfway" do you mean in the centre of the gauge, or halfway into the white (boost) side? My 94 850 T5 (B5234T) boost gauge shows about 80% into the white when you give it some lolly. It feels about right too. Is your 2.0 labelled 'Turbo' or 'T5'? If the engine is a B5204T2 it will boost lower as this is a 180hp engine, the B5204T3 is high boost and 166kw(223hp)
2008 XC90 D5
2014 Nissan Leaf
1973 Fiat 125
1970 MGB GT
1973 Land Rover Series 3 flat deck.
Previously:
2003 V70T5
1996 850R sedan
1994 850T5 Sedan
1995 850 Turbo Wagon
1998 V70T5
Favourite line: "How hard can it be?"
christhekiwi
Hi Marco, yes a 2.3 Turbo. The 2.0L is a T5. I would love to get more bottom end out of the 2,0L. Any ideas?
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 20 times
Post by jblackburn »
I think the 2.3 has pretty gutless bottom-end power, so that 2.0 must be a real slug.
You can try a turn or two shorter on the wastegate actuator rod on the turbo. Make sure that all of your vacuum lines are in good shape, and that your turbo hoses are all in good shape.
The get-up-and-go off the line is pretty much done without any assistance from the turbo, though. That means you need an engine with good top-end strength still. A compression test would give you an idea of how it fairs still in this age. A Seafoam treatment definitely helped me get back a little pep from a stop, and dramatically improved how smoothly it accelerates now.
'98 S70 T5
2016 Chevy Cruze Premier
Marcobrick
The 2.0l T5 allegedly has the same power and torque as the 2.3, I don't remember at what rpm though! you should have nearly full boost by 2300-2500rpm, if not you may, as I do with the V70, have a Vacuum leak or BCS fault. I have found a proper boost/vacuum gauge to be very helpful in diagnosing the turbo control system.
2008 XC90 D5
2014 Nissan Leaf
1973 Fiat 125
1970 MGB GT
Previously:
2003 V70T5
1996 850R sedan
1994 850T5 Sedan
1998 V70T5
