99 S80 hi beams
Everything on the Volvo S80. Sometimes called an "executive car", the S80 was Volvo's top-of-the-line passenger car. P2 platform.
Carrasaurus
Year and Model: Xc9p
99 S80 hi beams
Post by Carrasaurus »
My 99 S80 hi beams do not stay one - and YES the light switch is in the ON position at 12 o'clock. The beams works but do not stay on. I've read all the posts about making sure the light switch is on, but mine still won't stay on. Can someone offer any insight? Thanks.
Carrasaurus
Where is the high beam relay located?
dcarlson12
Year and Model: 1997 850 T5
Been thanked: 2 times
Post by dcarlson12 »
Do you by any chance have fog lights? If the fog lights are 'on', then the high beams won't go 'on'. Found this link to on line manual which confirms this. i.e. the flog lights only work if low beams are 'on'.
http://new.volvocars.com/ownersdocs/199 ... b.htm#pg30
Carrasaurus
Thanks for the reply, but the fog lights are not on and still no high beams. The car has been like this since I bought it in 2003 and original owner told me he never got them to work either. Never bugged me but now after all this time I failed Virginia safety inspection because of it. Go figure.
If someone could tell me where the hi beam relay is, I'd like to replace it. Thanks.
537playing
Year and Model: 2005 S60
Has thanked: 1 time
Been thanked: 5 times
Post by 537playing »
Are you pulling the level in towards you? You must push the level away from you to lock them on.
