The CEL Just Won't Go Away - P0072 - 2004 XC70
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
mse
Year and Model: 2004 XC70
Post by mse »
I have 2004 XC70 that is showing a CEL. I checked and the code is P0072 - Ambient Air Temperature Sensor Range/Performance. The CEL came on after I replaced the driver's side mirror housing - so I believe the two are connected. The outside air temp seems to be working fine based on the fact it shows on the dash display. I've checked the wiring harness and it seems to be connected correctly.
The only thing that I can think might be causing this code is a faulty temp sensor, which would be odd given the mirror housing and all of the parts are brand new. I thought about trying to replace the sensor with a new one, but cannot figure out how to pull the old one out of the current wiring harness.
Anyone have any thoughts on this? I just want to get rid of the CEL in case something serious does happen that I need to look into. The car is running perfectly fine otherwise.
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
I think that's one of the many parts that needs to be "initialized" by the dealer.
I'm not 100% sure but if it does (need to be), and you didn't have this done, that in itself would throw the code as it's now not "mated" to the car.
Call your dealer
jimmy57
Been thanked: 320 times
Post by jimmy57 »
The dash display is the RH mirror and the ECM is wired to one in the LH mirror. Recheck your installation for a backed out wire at the connector on the body side or to see if any of the pins got bent over.
mse
Post by mse »
Alright. Looks like I've got a couple of things to look into. Thanks for your thoughts on this issue.
proton
Year and Model: 2005
Post by proton »
"The dash display is the RH mirror and the ECM is wired to one in the LH mirror."
do you have the part number for those? can't find it online (2005XC70) I have that code too. My dash is ok but using the Android "Torque" application, I notice that the computer see a different temp that drop slowly to -40! so it is the driver side, right?
