Spent over $1500 recently on maintenance items such as timing belt, water pump, seals, windshield, battery, radiator, starter, tuneup, seals, MAF, engine mounts. Owned since 120k, only used synthetic oil.
A/C works, traction control works, ABS module got repaired, new throttle body, tires still in decent shape.
Transmission recently started acting up when warm, miss shifting, downshifting etc, dropping out of gear, however - drives fine when cold. Check engine light went on so did the Transmission service required light. Intermittent low boost condition.
Good as a parts car.
Clean NM title.
$1500 obo.
Will need to get towed.
Looks like this, same rims, same color. Actual pictures will be posted later.
