Can one lubricate the window slides? If so, with what?
Everything on the Volvo S80. Sometimes called an "executive car", the S80 was Volvo's top-of-the-line passenger car. P2 platform.
dcarlson12
Year and Model: 1997 850 T5
Been thanked: 2 times
Post by dcarlson12 »
99 S80 T6 and son's and wife's 94 and 97 850's:
Is there something to use to apply to the window 'slides' i.e. the vertical 'seals' which the guide the windows up?
I notice that my driver's side window seems to be labouring when being raised and similarly on my son's passenger side widow. I have tried aerosol/liquid silicone spray via the small red tube and it didn't seem to make much difference. I am worried I will wear out the motor or cause the slides of the window raising mechanism to fail if I can't reduce the friction....
yuckuJackD
Year and Model: XC70; S80; S40
Post by yuckuJackD »
You need to replace these parts:
And this is the reason:
In case you get late with this repair there is a big change to damage the window lift mechanism. Lubricating is done with grease.
Here is a write up (in Bulgarian) click but there are a lot of pics showing the whole process step-by-step so don't mind the foreighn language.
GOOD LUCK
p.s. There are two of them in each door, so for the front doors you'll need 4 pieces.
GOOD LUCK
A member of VolvoClub Bulgaria
Of All The Things I've Lost,
I Miss My Mind The Most.
VOLVO 440 1.7i 89y. B18E
VOLVO 460 1.8 mono 91y. B18U
VOLVO S40 1.8 115hp 16V 97y. B4184S
VOLVO S80 2.9 200hp '00y. B6294S
VOLVO XC70 D5 185hp '06y. D5244T4
dcarlson12
Thks for the reply. If one lubricates the blue 'slides' can one avoid having to replace them?
SimLyons
Year and Model: 2001 V70 T5
Post by SimLyons »
Try a VERY light application of lithium grease. it cleans up well and resists water.
Sim
dcarlson12
Hi Sim,
Are you referring to the internal slides (blue plastic as shown it the photos) for the lithium grease? Or the 'external' vertical slides/seals?
