67 122 Dual Circuit brake conversion
britfettle
Year and Model: 1967 122S
Post by britfettle »
The Single circuit brake master cylinder that came out of my '67 car had the activation rod/yolk attached to the cylinder -- which oriented the brake pedal for adjustment. The new dual circuit master (including adapter) has an activation rod which is not attached to the cylinder bore and just sort of floats there -- making it impossible to use this new rod to position the pedal as before. The only solution I can think of to orient the brake pedal in its proper place is to fabricate some sort of pedal stopping bracket inside the footwell -- which seems unfortunate. Has anyone encountered this problem? I could possibly take the seals from the new cylinder and rebuild one of my parts '68 brake master cylinders (dual and no adapter needed) if the bores were the same. Thanks, Stephen
9394volvo850s
Year and Model: 93 850 5spd 94 850T5
Post by 9394volvo850s »
lemmie know what route you go with this, im still running the single circuit master in mine. and ive thought about converting it over.
93 850 5spd 320k (the daily)
94 850 T5 190K (race car)
95 T-5R wagon yellow (summer wag)
90 745 5spd 295k (winter wag)
67 122 2 door 4spd 69k :))
Vauts1800
Year and Model: P1800 1966,240
Post by Vauts1800 »
Hi
You remove the circlip holding the original push rod in place and transfer it and the retaining washer over to the new master cylinder. Presuming you are using the same bore size cylinders
Rob
