I have a 2000 S80, this car sat in a field for 3 years until about a month ago. Several parts were missing and seats were removed. I have managed to get the car all back together and have been driving it. I have driven 1.5 tanks of gas and now after the car is running for about 10 minutes it will start to shutter when idle. About two minutes later the car will go into limp mode and you will see engine system service urgent. I checked the codes and I get p1611, p1613. If I were to guess I would think its a bad sensor somewhere. It might also be fuel filter, fuel relay or something like that. I can't find much on the trouble codes, anybody have any ideas?
Thanks.
Eric
Limp Mode & Trouble Codes - Help
dcarlson12
- Year and Model: 1997 850 T5
- Been thanked: 2 times
Googled and found this like to a page on this site. I couldn't get the pages to open up when you click on the trouble code links in the pull down menu above under 'Repair Database'. Not sure if I am doing something wrong???
https://www.matthewsvolvosite.com/forums ... =9&t=25110
Sounds almost like throttle position sensor. Not sure what ETS stands for ???
Edited Nov21:
Have added the file herewith that shows the DTCs of 'Generic' versus Volvo DTCs
Both codes are defined as Throttle unit communication: Signal too high or signal missing
Edited Nov21:
DTCs generic versus Volvo.pdf- (107.1 KiB) Downloaded 199 times
kiteoregon
- Year and Model: S80,2000
Thanks for that, it would look like it's a ECM902A - Signal Too High or Signal Missing, points to ETS / ECM wiring or module fail. I also read that this could be the MAF as well. I see others with the similar issue, but i don't seem many that post the result.
- 4367 Views
Last post by jonesg
- 15 Replies
- 2498 Views
Last post by krenekj
- 949 Views
Last post by Ozark Lee
- 2289 Views
Last post by Waldenbound
- 3189 Views
Last post by c70_lindsay
