How to check a Parasitic Draw on battery
shelly4278
- Year and Model: s40 2005
Does anyone know the cheapest way to check for a battery drain? My battery has slight draw. I do not know where it is coming. from. I have a 2005 S40. I replaced the Battery about 10 months ago. The battery has been checked and its a good battery. I am checking to see if lights have been left on and still cannot come up why my battery is draining.
JDS60R
- Been thanked: 3 times
Lots of post here on the topic. use the search above.
Basically
1. Remove positive battery cable
2.Place meter with amp draw setting between battery and removed cable.
3. Pull fuses one at a time until you find the one or two that effect the draw reading on the meter.
4. Inspect/unplug the devices on that circuit until you find the one with the draw.
5. Repair as needed
Basically
5. Repair as needed
Retired
shelly4278
Thank you for your response. I just called a automotive repair shop. They said for $15.00 they could check for the draw. If it takes more than a hour then they will charge for Labor. I'm thinking its a fuse. The Alternator Test out fine.
shelly4278
Do you think it is a relay. What draws ampage?
JDS60R
Everything that takes electricity to run will draw amperage (lights,radio,sensors,gauges,fuel and air pumps,horn,airbag monitor system,engine computers etc)
They are switched on and off by the use of switches ,relays and computers.
Wires provide a path for the electricity and fuses protect the wire from burning up in case the device tries to draw more amperage than the wire can handle.
Retired
shelly4278
I took my car to my Mechanic today and he is going to run the proper tests on it. I will get back to you and let you know what caused the drain.
- 2686 Views
Last post by Cees Klumper
- 1839 Views
Last post by pb49415
