cant find oil leak!!!
JonFreeman938
Year and Model: 850, 1995
Post by JonFreeman938 »
I have had an oil leak forever that i cant find, But it only leaks SOMETIMES. which is really strange. I can go for weeks without it leaking, then sometimes it will just start leaking. it always leaks, if i top the oil off. so i try to just keep it in medium range on the dipstick to keep it from leaking. I have looked down into the engine and i cant see anything. under the car the oil is on the transmission and the oil pan area. maybe the oil pan? any ideas why it only leaks sometimes?
charlyW
Year and Model: 97 855 T-5 CD
Post by charlyW »
could be the PCV in need of a change, Most of this is under the inlet manifold not hard to change but one of the critical bits that needs regular upkeep. Drain plugs do fail after a while too as does the oil filler cap seal might be good to replace them all at once or get your mechanic to do it for you
855 T-5 RHD Blue: MBC, Custom Map based on Rica, K&N Filter, 18T Turbocharger, White/Green injectors [depends on my mood], Blue Silicone vacuum hoses
