Each morning, or after car sits a while there is a noise from the left front wheel well/firewall area. Similar to a small spring breaking or when the abs pulses.
Only seems to happen when its been sitting a while, and only does it once each time.
Car is 99 s70 t5 auto.
Noise at 12 MPH. ABS module?
JRL
- Year and Model: Several
- Been thanked: 16 times
Probably
turbozutek
- Year and Model: 1995 850 GLE
My car does a similar thing but from the REAR wheel. It sounds sort of like a 'scrape' noise.
I think it might be a knackered wheel bearing (already renewed the discs, pads and shoes at the back), but there's no other symptom so I'm going to leave it until it starts growling.
Chris...
Chris...
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
It's just the ABS self test.
'98 S70 T5
2016 Chevy Cruze Premier
FlyingVolvo
- Year and Model: 2000 V70XC
- Has thanked: 51 times
- Been thanked: 74 times
It also states in the manual that it does this. At 12 MPH after the car has been started, the ABS performs a self-test. It sounds exactly as you described, and you may even feel a little quick vibration.
Perfectly normal.
Perfectly normal.
2000 V70XC - 340,000 miles
2023 V60 T8 PE
2023 V60 T8 PE
- 11 Replies
- 7281 Views
Last post by Vovoroom
- 2230 Views
Last post by SuperHerman
- 1151 Views
Last post by kevplank
- 1400 Views
Last post by hotwheelsndeals
- 6109 Views
Last post by misha
