Parts failure poll for P2 generation: let's do it right
This topic is in the MVS Volvo Repair Database » Last Call for 2001+ Volvo Problems V70, XC70, S60 etc.
Locked
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2857 times
Been thanked: 1332 times
Post by matthew1 »
Let's do the same thing as with the new 850 [and siblings] poll: let's do it right. We're going to start from scratch (sorry Dan) with every failure we can think of, up to 100 of them. You'll be able to vote on all 100.
If you have two P2 cars, the only way to vote for one failure twice is to create a second MVS account, then log in under that one and vote. Or three, or four, etc. It's not a problem from my perspective if it's not one from yours. The only catch is you need to use a different email account than the one you used for your current MVS account.
So far we have
  • Front/rear wheel bearing
  • Tie rods
  • Sway bar links
  • Control arm bushings
  • Lower ball joints
  • Upper Engine mount
  • Transmission (including software upgrades)
  • Radiator leak
  • Gas tank pressure sensor
  • Siren control module
  • Vacuum pump/vacuum switch
  • Engine cooling fan
  • Climate control fan
  • Anti-Skid Service Required, Yaw sensor
  • Brake cylinder position sensor
  • Exhaust pipe hanger broken (rusted)
  • Front window mechanism, slider or switch
  • Driver side - cover of seat controls broken
  • Door whether strip detached
  • Fuel pump
  • Rear latch mechanism
  • PCV system
Suggested already to add:
  • rear main seal replacement
  • delaminated shoe on the parking brake mechanism
  • defective lower ball joint
  • premature lightbulb/bulb socket failures
  • steering rack replacement
  • the turbocharger (whole thing)
  • gas door hinge
  • cup holder
Please suggest failures until your head explodes, or it's 5pm and time to leave the office, whichever comes first. I'm going to disable voting on this current poll. Results from this current poll will not be carried into the new one, unfortunately.
Also -> Amazon link
fazool
Year and Model: S60, 2007
Been thanked: 7 times
Post by fazool »
alternator
steering rack
gas door latch (not hinge)
center console cup holder cover
wheel bearing
rear bearing housing ("knuckle")
front light sockets
2007 S60 2.5T AWD (Daily Driver)
2001 S60 2.4T (Daughter's Car)
2003 S80 2.9 (Son's Car)
1995 850 2.4 (Daughter's Car - sold off)
2005 S40 2.4i (Bought new - since sold)
1986 740GLE 2.3(First Volvo - sold off)
ashgoldS60
Year and Model: 2001 S60
Post by ashgoldS60 »
ETM (electronic throttle module)
discolored roof trim strips
ashgoldS60
forgot to add:
immobilizer attenna (Start Prevented error)
broken ignition lock (key cannot turn)
ignition key failure (key replacement + Programming (haa!)
matthew1
Site Admin
Post by matthew1 »
Perfect. Keep Em coming.
Also -> Amazon link
matthew1
Site Admin
Post by matthew1 »
We're open 24 hours a day ;-).
Also -> Amazon link
dan777
Year and Model: 2006 V70 2.5T
Been thanked: 4 times
Post by dan777 »
Hi Matt,
I had a list that I put together after you allowed more then 22 entries but it was to late to change the poll.
Here it is:
Tie rods
Sway bar links
Lower ball joints
Front struts
Spring seats
Steering Rack
Axle shafts
Upper Engine mount
Transmission mount
Radiator leak
Engine cooling fan
Climate control fan
Climate system (including software upgrades)
Brake master cylinder
Emergency Brake cable
Oxygen sensors
Fuel pump
Fuel door hinge
PCV system
ETM (throttle module)
CEM (central electronic module)
ABS module
Alternator
Turbocharger
Turbo valve
Ignition coils
Ignition lock
Driver seat motor
Turn signal issues
Steering wheel controls
Passenger airbag sensor
Various cabin switches
Various light sockets issues
Center console cover / center cupholder
Dan
2000 V70R (sold)
2006 V70 2.5T
matthew1
Site Admin
Post by matthew1 »
Nice, Dan. Thank you.
Also -> Amazon link
dan777
Post by dan777 »
Hi Matt,
I have this idea which I am almost sure you will say that is too complicated to implement in a poll, but at least please give it a thought:
Would be really nice to have the failure mileage included in this poll, that way we should know not only what to expect but when.
The way I think this is possible is to create for example 5 columns or more, each column for a range of 20k miles (0-20; 20-40; 40-60; 60-80; 80-100, etc.) So when somebody votes for a certain part they have to put the vote in one of these columns.
What do you think?
Thanks,
Dan.
P.S. If you need any help with this poll (with or without mileage) please let me know.
Dan
2000 V70R (sold)
2006 V70 2.5T
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
One not in here (don't know how common but was a problem w/ my wife's '04 V70):
Camber adjustment not possible on front end...requiring camber bolt kit...said it was due to "settling" or sagging of front end although front struts and related parts are all in good shape. Don't know how to word this problem exactly.
Locked
