97 volvo 960 with 150,000 miles. Started idling rough with p0302 code.
I swapped coils around and still had same code. So i swapped the ignition control models around and then got a p0305 code.
This made me believe that the Ignition control module was bad. I replace the module and I still get the p0302 code with the new module and if i swap it with the other one then I get the p0305 again. What is the chances that the new part would be bad causing the same cylinders to missfire? Vehicle runs fine at higher rpm. Any suggestions?
Help with misfire codes on 97 960
- 19 Replies
- 9304 Views
Last post by Barledge
- 738 Views
Last post by father ted
