Transmission fluid/filter change for a '99 S70
KBCobra
Post by KBCobra »
How often should you change/replace the transmission fluid & filter on a '99 S70 8nder normal driving conditions and no towing?
Thanks,
Keith
Jot
Year and Model: C30 2010
Post by Jot »
Volvo doesn't use filters on the transmission. It wouldn't hurt to do a drain and fill ,about four quarts , every 20 K
White850Turbo
Post by White850Turbo »
Whenever you do it, you must use either the official Volvo fluid or the Mobil type 3309 fluid unless you want to buy a new transmission some time in the near future.
-Sean
1998 S70 T5 (Almost Stock)
Jot
Post by Jot »
Check this site http://www.volvospeed.com/volvo_performance.php If your transmission is a 5 speed automatic Yes you must use synthetic fluid .If yours is a four speed Dextron 111 will be OK I have used Dextron111 for many years 176 K on one (now totaled) The other 193K
