95 Volvo 850 Oxygen sensor (B5252 engine)
Vanillagorilla
Year and Model: 850, 1995
Post by Vanillagorilla »
Hello all,
Recently my O2 sensor light came on on my dash and, in looking for a replacement part, I've hit a major road block. My car has the 10 valve Canadian engine (B5252) which apparently only has 1 O2 sensor. Every auto parts store I call seems to think that I have 2, which tells me that their books assume that I have the 20 valve engine. Volvo parts seems to know what part I need, but they want to charge me $397 Canadian for it. I'm hoping that someone out there can tell me what the Bosch replacement part number is so that I can order it online and save a truck load of money.
Any help would be greatly appreciated.
Thanks
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
As the stealer is the part for the other 850 are the same part #. If so, go get one from a salvage yard.
Vanillagorilla
I'd really like to avoid installing a used sensor. I'm sure that I can find a new one on Amazon for a reasonable price. I just am not sure what part number to order. Amazon (like all websites I've searched) assumes that I have the 20 valve engine.
turbozutek
Year and Model: 1995 850 GLE
Post by turbozutek »
IIRC, that O2 sensor is not made by Bosch. On the European 10valves, the O2 Sensor is made by a company called DENSO.
http://www.lambdapower.co.uk/partsearch ... t=LP-20504
That's the good news, the bad news is that even here the cheapest part that fits is £130 ($245 odd). The worse news is that universal sensors don't work for shit on these engines - the ECU throws the toys out the pram really quickly.
I'd get you more information, but the UK Volvo forum is down right now... When it's up give it a wee search; there have been many threads on the 10 valves emissions systems.
Chris...
precopster
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
I have a 10 valve (Australian) 850 and turbozutek is right on the ball except for the brand and link. I believe the link below will help.
Don't bother with a Bosch part. The 10 valve runs on a Siemens ECM and they chose to configure their programming for the O2 sensor for a TITANIA class sensor.
These sensors switch differently. If you put in a Bosch as I first did the engine will run beautifully for the first 15-20 secs when cold then all hell will break loose.
Just Lambda has your sensor: http://www.lambdasensor.co.uk/main/volvontk.htm
OTA4N-5A1 or OTA4N-5B1 is the one to use depending on your model year.
They list an NTK brand which is exactly the brand the factory fits.
Vanillagorilla
Thanks you for all the help. My Volvo is not listed in your link. Mine is a non-turbo 2.4litre with the b5252 engine. Any other ideas?
precopster
They're known as either 2.4 or 2.5 litres depending on the foreign market they were sold in. All engines were 2435cc in capacity or if turbo R models were 2.3 litres, but these all had Bosch ECMs.
The OEM number you require is 3507256. Run this past them at Just Lambda. I'm certain it will be a match.
Also look at the wire colours from the sensor . They should be:
Black Ref. (out)
Yellow Ref. (in)
Red Heater (+)
White Heater (-)
these colour combos are only used with Titania O2 sensors.
Vanillagorilla
Just lambda does not ship to Canada... Anything that ships to Canada or the USA will work. I have an address just across the border.
precopster
turbozutek
Yeah yeah, DENSO is maybe some ME7's the more I think about it. I have a 20v so it's a Bosch, but I could vaguely remember a bunch of threads on volvoforums.org.uk lamenting the O2 sensors on 10 valves.
Ok, as for buying from the UK - I can buy the part and ship it to Canada air-mail if it helps, just let me know!
Chris...
