Ham Radio Wiring
How to integrate your phone into your Volvo's audio. Which speakers to buy to replace old ones. Recommended head unit brands and models... This is where we talk watts, ohms, GPS, iPod integration, component installation, tips, tricks and advice for making your Volvo's audio, video, ticket avoiding and mapping gadgets work better than ever... iPod, XM, GPS, DVD, Speakers, Amps, Radar Detectors
Ubbm
Year and Model: 850 Turbo 1996
Ham Radio Wiring
Post by Ubbm »
I am installing a 2 meter amateur radio in my 850. I need to run wires through the firewall to the battery positive and to the engine block ground/earth. Where is the best place to go through the firewall?
1996 850 Turbo Sedan
2002 VW Passat 4-Motion (wife's wheels)
1984 F-150 4wd.
Previous interesting vehicles:
1974 Ferrari Dino 246 Spyder
1973 Bentley S Sedan
1956 Jaguar XK140 Roadster
1929 Salmson (first production DOHC engine)
1926 Darracq Tourer
JDS60R
Been thanked: 3 times
Post by JDS60R »
Look around the brake booster. There is already a rubber grommet with multiple size tubes sticking out of it. Remove the grommet and cut off the end of the tube you need to use. Then re install. Make sure fit is tight so you don't let outside air or gasses into the drivers compartment. Armor all or a mix of 1/2 quart water and 4 drops baby shampoo make a great lubricant to help slide the wire through. Dawn or similar dish washing liquid and water can be used as well. Remember the car is galvanized so you will need to find strong grounding points so you don't fry your signal amplifier. A poor ground will directly effect performance and longevity of the unit.
Retired
Ubbm
Post by Ubbm »
JDS60R,
I really appreciate your professional reply to my question. And "right on". I had seen that tube and wondered what it was (!) but never would have guessed that Volvo would be so considerate. Anyway, it is installed and working. Thanks :)
1984 F-150 4wd.
1926 Darracq Tourer
