I have refitted my water pump twice only to find coolant slowly dribbling out from the under side of it. Both times I have used the standard paper gasket. I am thinking I will try permatex in the hope of really getting that thing to stay on (in addition to using brand new bolts and nuts next time). Any reason why permatex would be a bad idea? Or any pointers on using permatex for this application?
Thanks,
Eric
86 740 235K mi.
86 740 water pump - paper gasket vs permatex
writer100
- Year and Model: 940 1994
I've used permatex in the past with success. Follow the instructions.
Also, I believe on your water pump there is a rubber gasket at the top. This is a pressure fit against the head, and must be held under pressure until the pump is torqued down. It is helpful to have another set of hands for this.
Good luck.
Good luck.
1994 Volvo 940: 189,000 miles.
2008 Mustang GT convertible: 10000 miles. The garage queen.
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
I haven't used Permatex but I am a firm believer in using a gasket sealant when fitting water pumps. On two occasions when I didn't use a sealant they leaked.
The sealing ring on the top does need to be held firmly in place so how quickly can you grow two more hands?
Bill.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
fazool
- Year and Model: S60, 2007
- Been thanked: 7 times
Make sure your surfaces scraped/sanded clean. Paper gaskets are junk but they work because they are cheap and easy to assemble on a new motor (where everything is flat and smooth and clean.
Frankly, I've always put a bead of permatex, then the paper gasket, then another bead of permatex.
Sounds stupid but I've always had good luck.
2007 S60 2.5T AWD (Daily Driver)
2001 S60 2.4T (Daughter's Car)
2003 S80 2.9 (Son's Car)
1995 850 2.4 (Daughter's Car - sold off)
2005 S40 2.4i (Bought new - since sold)
1986 740GLE 2.3(First Volvo - sold off)
e777
- Year and Model: 1990 740
- Has thanked: 11 times
Fazool,
I followed your advice and the pump is totally solid and leak-proof. I laid a bead of permatex on the pump edge, where the gasket sits. I pressed the gasket onto the pump and then laid a bead onto the side of the gasket that mates with the engine block, and fit the pump to the block. No leaks after weeks of use! Thanks a million.
Eric
86 740 wagon
90 740 wagon
91 240 wagon
Eric
86 740 wagon
90 740 wagon
91 240 wagon
Wagons:
93 940
91 240
90 740
86 740
93 940
91 240
90 740
86 740
- billofdurham
Good job. Thank you for the update.
Bill.
Bill.
Previously:
Previously:
- 695 Views
Last post by manovlov
- 25 Replies
- 14162 Views
Last post by Antherzoll
