V70 engine swap
Petero635
- Year and Model: 850T5 1995
V70 engine swap
I have a 1999 V70 2.5t with a valve problem can any tell me if it is possible to put a 2002 T5 motor in and what do I have to do such as ecu does that need changing and also I have a auto AW50-42 do I need to change the transmission ecu as well or can I just fit a long motor with turbo in to the car with out much mods. Thanks if I have to repair I may as well up grade the motor.
jimmy57
- Been thanked: 320 times
The t5 engine will work but you may be disappointed with the performance. The network on the car will prevent you from swappping ECM from a t5 car into that one to get the full potential of the t5 engine.
- 932 Views
Last post by MadeInJapan
- 15 Replies
- 4825 Views
Last post by soulvoid21
