Anybody know a test to see if the coolant level sensor is bad? Low coolant light is on but the expansion tank is full. Just replaced the tank, guessing leaking coolant or the removal/reinstall might of broken sensor but would like to test it if I could before ordering a new one.
thanks
Test for failed coolant level sensor?
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
That's your test. The sensor's bad if the coolant is full and it's still showing the light.
'98 S70 T5
2016 Chevy Cruze Premier
I had the same thing happen when I replaced my tank. Replaced it with a new sensor, and the light went off. The only downside is the replacement was an aftermarket brand and it doesn't trigger the light until the coolant is at a much lower level than the original sensor worked at. I'm planning on putting a Volvo sensor back in soon, as I don't really trust the one that's in there now.
Sent from my SGH-T679 using Tapatalk
mikealder
- Year and Model: V70 2000
- Been thanked: 13 times
Slide the expansion bottle off its bracket leaving the pipe connected and the cap on, turn the bottle upside down and give it a good shake, refit bottle to the car and check the low coolant light is off, if it is the sensor was stuck, if its still on the sensor is shot - Mike
db130
- Year and Model: 2002 V70 T5
pull the sensor from the bottom of the coolant tank - is the light still on? then it's a bad sensor
just because the light is on when the coolant is full doesn't make it a bad sensor - if the float inside the tank is stuck at the bottom, it will still trigger a light. however, since crash813 already replaced the coolant tank(presumably with a new one?) you are most likely looking at a faulty sensor.
2002 V70 T5 169k
2002 V70 NA 249k
2006 Mini Cooper S 90k
2002 V70 NA 249k
Dependant on the model these sensors work on ohms readings & not a float device. A simple multimeter will be able to verify if the sensor is faulty or not.db130 wrote:pull the sensor from the bottom of the coolant tank - is the light still on? then it's a bad sensor
abdomar528
- Year and Model: S80 T6 2001
- Been thanked: 2 times
This thread is so old but I thought I'd comment anyway. Check out my video here:
I bought this new tank online and it was a Volvo genuine coolant tank. After 10 days it went bad. I did this test where I compared it to a new tank and I realized the tanks float mechanism is bad.
Watch the vid and comment!
- 4191 Views
Last post by Roger_850T
- 48738 Views
Last post by ggleavitt
- 12 Replies
- 7190 Views
Last post by RickHaleParker
- 4919 Views
Last post by ndphotonl
- 1362 Views
Last post by cuhfs
