fuel leak
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
mitchellbd
fuel leak
Post by mitchellbd »
Hi
I have a 2002 v70xc and also a fuel leak.
I think the leak is where the hoses go into the tank but I'm not sure where that is.
In fact it looks like my car has 2 tanks. The one in the drivers side has an access panel
but under it is what could be a pump but has no hoses just some thin wires I think could be
for the gauge or computer. Is there a second access plate or do I need to drop the tank?
Mitchell
regent
Year and Model: 2015 XC60 T5
Has thanked: 2 times
Been thanked: 12 times
Post by regent »
Hi Mitchell,
The fuel pump and tank level sensor are accessible from the top (no need to drop the tank). The pump is on the right side under a similar access panel. There is a strict procedure that calls for draining the tank and a special tool to detach the pump.
You want to check first with the stealership if you are still eligible for the recall on the fuel pump with those symptoms. (I think the warranty on the FP and the O-ring was extended to 10 years, but its best to give them a call).
Hope this helps.
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired :(
1987 340 DL - retired :(
