NO I am NOT Swapping the turbo to the N/A engine.
YES I AM swapping the turbo engine into the N/A 'goon.
YES I DO want to know what all I NEED to change electronics wise.
I realize that this is a large undertaking, engine, pipes, exhaust, computer, dash cluster.. but do I need to swap the engine harness? Seems to me it should almost be a plug and play. Both cars were manufactured very near each other, both are OBDII, and both are 'goons.
My GLT only needs a turbo drivetrain to be "THE" car that I want. It has everything else. I am planning on a 5 day swap total:
1st day: Remove N/A engine and Turbo engine, start swapping components between cars.
2nd day: Finish swapping all components over to GLT that are needed, and place GLT parts in Turbo car. Also, service engines (PCV, RMS, T-belt waterpump etc. and place N/A throttle body onto Turbo engine!)
3rd day: Install Turbo engine into GLT and get it driveable!
4th day: Install GLT engine into Turbo car and get it driveable!
5th day: Finish up any loose ends, and sort out any codes there might be and Done!
Thoughts?
N/A car to Turbo!
RDEJR
- Year and Model: 850 GLT Wagon, 1996
N/A car to Turbo!
My T5 never chirps tires - it's a slow fat whale from a stoplight. - jblackburn
1996 850 GLT Wagon (Soon to be Turbo!) - Black and Mild
1995 850 Turbo Wagon - Sleeper 'goon.. never giggled so much...
FlyingVolvo
- Year and Model: 2000 V70XC
- Has thanked: 51 times
- Been thanked: 73 times
You're nuts.RDEJR wrote:Thoughts?
2000 V70XC - 340,000 miles
2023 V60 T8 PE
2023 V60 T8 PE
precopster
- Year and Model: Lots
- Been thanked: 128 times
The OP has chosen the easiest way to get the job done. A donor car is really the only way otherwise too many trips to pick & pull.
Mind that the springs may be lower on the turbo car so swap them too. Watch out for larger diameter sway bars also.
If you have a copy of Vadis you can cross reference everything to be sure.
Also mind that when it comes time to sell you may have actually devalued the car for the majority of buyers.
- Has thanked: 292 times
- Been thanked: 765 times
Yes, you need to swap the engine harness. And maybe more I don't know, but I am sure about the engine harness.
Also, your timeline seems a little compressed.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
JRL
- Year and Model: Several
- Been thanked: 16 times
Would be easier and probably cheaper to just buy a turbo car in the first place
precopster
5 days to sort two cars?? If you work 24/7 maybe......
bigdaddylee82
- Year and Model: '95 850 GLT+94 parts
Haha, I piddled around for about 7 months to swap a non-turbo engine into my non-turbo GLT.
I wish you all the best, please document it all.
This very swap has crossed my mind more times than I care to think about. I figured "simple" solution would be keeping all original non-turbo wiring and piggy-back fuel/spark control with something like a Split Second PSC-1, or just going Megasquirt.
- Lee
- Lee
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Please post back your results. We would like to know what happens.
My opinion would be to dump both cars and purchase a turbo. I'd fly 1,000 miles to get a car that I could keep than to try a motor swap.
what is neede is the complete motor with wiring harness all the way to the computer harness under the computer box and the ecu it is easier done by pulling the k frame and swapping the complete k frame from one car to another i am doing this myself will probably have it done in my friend shop in a weekend it is not that hard as alot of people here say it is
