replacing control arm bushings
Replace Control Arm Bushings
Andy Berry
- Year and Model: 1992
i need to replace the control arm bushings. i asked a guy for an estimate and he said 'upper? lower? inner? outer? front or rear?' really....i wont be going back to that guy but i need to know what to tell the mechanic i use. what exactly do i need to ask for, for a 1992 740 wagon?
Andy Berry
Central Texas
1992 740 wagon
Central Texas
1992 740 wagon
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
He was covering all of the bases and some that didn't need covering. The control arms are part of the steering/suspension and each control arm, one right and one left has two bushings which could be called inner and outer. I would replace both at the same time. There is also a control arm stay which has one bushing and this should be checked and replaced if necessary. The attached from VADIS shows the bushings, parts 8, 10 & 11, on the front. They are the same on the other side.
The rear suspension does not have control arms. It has support arms and torque rods which do have bushings. If you have been told you need control arm bushings it is the front.
Bill.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
trying to replace control arms in 1996 960. Cant find parts: IPD says they have no complete arms, only Bushings. FCP lists Meyle part 516 050 960 1 and 2. These do not fit at the ball joint end as Meyle parts are about 60mm wide while the OEM parts are about 40mm. Hence it cannot fit the knuckle. Can anyone help with a valid part number or am I left with only option to replace bushings in old arms.
THX
THX
lummert
- Year and Model: 760 1988
- Been thanked: 26 times
Control Arm - Front driver side lower: Volvo 274451
Control Arm - Front passenger side lower: Volvo 274452
Bushings are available.
Control Arm Bushing - front (rear): 9191537
Control Arm Bushing - front (forward): (Lemforder) Volvo OE number: 6819537
all of the parts are listed at eeuroparts.com
1988 Volvo 760 Turbo Wagon
- 3029 Views
Last post by 800artfreed
- 13359 Views
Last post by MarcM
- 2973 Views
- 11 Replies
- 10751 Views
Last post by BlackBart
- 555 Views
Last post by DrJammer
