1996 VOLVO 850 GLT Wagon, Detroit Area ($2,700)
ShahinS
Year and Model: 850 GLT Wagon 1996
Post by ShahinS »
I’m reluctantly putting my meticulously maintained 1996 Volvo 850 GLT up for sale :( Because I’M MOVING!
I have owned this 850 for the past 6 years and ~80k miles.
I have put sooooo much $$$ into this wagon! I'm simply too afraid to add all my receipts at this point!!!....
Asking: $2,700
Facts:
VIN# YV1LW5554T2257694
Clean and Clear Michigan Title
Mileage: 209,500
I am the 3rd owner (the 2nd owner only had it for few months, so practically I’m the 2nd owner).
The first owner serviced this car at the dealer; there are dealer stamps in the maintenance log-book.
Oil change every 3000 miles (Non-Synthetic Valvoline Max-Life, with OEM MANN Filter)
Very Recently Done:
Both Front & Rear Hydraulic Engine Mounts (OEM parts)
Front Trans Mount
Front Right Lower Engine Mount (OEM)
Upper Engine Mount (OEM)
Left Control Arm (OEM)
Left Tie-Rod (OEM)
Front O2 Sensor (BOSCH)
4-wheel alignment (although it needs rear tires, fronts are fare)
Replaced Last Year:
New Exhaust Manifold
Complete Steering Rack (Re-Built)
Front Struts & Spring Seats
Rear Shocks
Complete Brake Job: Front & Rear Rotors & Pads
Replaced in the Past:
Left Front Wheel Bearing
Right Control Arm & Tie Rod
PNP Switch
Evaporator Job was done ~4 years ago ($1400 at the dealer!) AC is blowing Cold Air.
Odometer Gear
Blower Motor
Tailgate struts
Trans oil was replaced, I believe ~30k miles ago, transmission works fine with no issues.
Newer starter motor (I think it was 3 years ago)
Faults:
There are paint chips on the front edge of hood, and the hood on the upper portion of the grill is slightly bent in plan-view. (The grill shown in the photos is available and will come with the car, but currently there is a grill on the car that has some broken bars, but it securely attached via the attachments).
The driver door needs to be shut with a tiny bit of extra force; all other doors are functioning as normal.
There are two tears on the driver seat.
Driver Heated switch light is not working, but both front heated seats works fine. (All other interior lights works; I have replaced the cluster, HVAC & console bulbs).
Driver seat won’t get lowered if it is raised; it is positioned at the lowest position now.
Hand-Brake is not connected and is not working.
When engine is cold there is a slight interference with the exhaust and the underneath cross-member bracket, after engine warms up all is good.
More Facts:
Heater works Great!
Stereo works, 6 CD changer works (even the cassette player works fine)
Highway: ~24-27mpg City: ~20-21mpg
T-Belt was done at 139k I have receipt for it.
(BTW, just in case you were wondering, the trackgraphics were put on as a joke, this car has never been to any race-track, although it would make for a good laugh!) :mrgreen:
Please PM me with your questions and offers, Thanks For Looking!!!
96 850 GLT Wagon
