I recently did an extended life tune up on my car:
Air Filter
Fuel Filter
Oil Change
New power belt
Spark Plugs
Coil wires
Distributor Cap and Rotor
Fuel Injector Seal Kit
All new vacuum lines
Upper and lower radiator hoses
Also replaced the camshaft positioning sensor
I go to try starting the car for the first time. It just cranks.. and cranks.. and cranks again.. I looked over all connections and everything is hooked up.. I check fuel delivery and that was a go. I checked the spark, and there was none. I traced the problem back to the Ignition Coil. I used a Volt Meter to check the power from the connector off of the engine wiring harness and it read about 12.4 volts.. but for some reason, there is no spark coming out of the ignition coil.. I think ok I'll just replace it, so I did.. different ignition coil, same problem.
IMPORTANT NOTE: This car is currently equipped with a very crappy Valet 551t Remote Start System. In the back of my head, I keep thinking that the car is in some kind of lock down mode, and its causing the ignition coil not to send spark.. is that even possible?? The wiring for the system is very sketchy. I tried removing the power to the system off of the positive battery terminal, but that didn't do anything..
I went to a local volvo specialist, $80 an hour.. The actual dealer was worse than that.. both the specialist and the dealer said, "sorry I wish I knew what to tell ya, you could bring it in and have us look at it?" ha.. that ain't happening, I'm 18 years old and I don't have a couple hundred bucks laying around!
I'm curious if anyone else has had a similar problem with either the Iginition Coil and no spark problem, or the Valet 551t issue?
Anything would help at this point, I'll try anything.. Its killing me have a beautiful conditioned 850 Turbo Sedan with 130k miles just begging to be driven, just sitting there..
