V70 Valve grinding question
jgerhard45
- Year and Model: 1998 V70 GLT
Does anyone know the specs on the height of the valve stem tip to the top of the valve guide to keep them in the range of the hydraulic lifters after grinding?
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
Volvo uses a tool that is a pipe that lays in cam journals with a hole that a vernier caliper or depth mic anvil can pass through. The pipe is the diameter of the journals. the depth from the top of the pipe down to valve tip is 48.5 +/- 0.4 mm.
jgerhard45
Is that for both the intake and exhaust?
jgerhard45
Thanks for the info, it helped a lot. Do you happen to know the intake/exhaust seat widths after grinding and lapping?
- 1621 Views
Last post by benpineapple
- 3771 Views
Last post by oragex
- 12 Replies
- 2043 Views
Last post by PapaHepcat
- 1272 Views
Last post by Matty Moo
- 2997 Views
