Can somebody Brand-Name recommend to me some decent ramps to use with my 98V70 normal suspension. My old red metal ramps would be hit by the front overhang. Are the plastic type ramps sold at AutoZone ok for using with this car?
I like to use ramps for oil and transmission fluid work as they have less of a tendency to sink into the hot asphalt that is my driveway. Been using a jack and stands on a metal plate for a while now. Getting sort of old and tedious for my frequent trips down-under.
V70 Ramps Recommendation
rmmagow
- Year and Model: V70 1998
- Been thanked: 2 times
1998 S70 135K - FOR SALE
2003 GMC Sonoma - 114K - POS
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
I have Rhino ramps (black plastic ones) I bought at Autozone and love them - they have been used at least once every 2 months for the past 5 Years. They're the smaller ones built to handle 4000 lbs.
'98 S70 T5
2016 Chevy Cruze Premier
- Has thanked: 2864 times
- Been thanked: 1332 times
Rhino ramps - same experience. Good product.
rmmagow
Thanks guys, Rhino Ramps today on the way home from work.
- Been thanked: 504 times
Wood Ramps for me. Info in here:
DIY: 98 V70 Engine Oil Change (& ATF Change): the Easy Way!
https://www.matthewsvolvosite.com/forums ... hp?t=42989
VolvoTurbo850
- Year and Model: 1994 850 (T5)
Rhino Ramps here.. no rust no bend.
The Fleet
2001 V70 (NA) 2.5
1999 C70 Conv. Turbo 2.3 HPT
1998 S70 Turbo (T5) SE
1994 850 Turbo (T5)
1980 Corvette (Corvolvo)
Previous Possessions: (4) 240's, (1) 740, (9) 850's, (5) 70 Series
Projects on the go: NONE... Yet!
rmmagow
Got my truck up on the woodies and it going to be there for a while. The Rhino's work great and fit in the back of the wagon for on-the-fly oil changes
My wood ramps have been around for some 20 years.
If you want to live then use Wood Ramps.
Re: Rhino Ramps, just Google "Rhino Ramp collapse" for some fun readings.
I do not want you guys to be killed/injured.
Do you trust some 3000-4000 lbs sitting on some hollowed out plastic ramps?
Not me.
So again google it.
http://gmlongroof.4umer.com/t410-anyone ... ino-before
http://www.tamparacing.com/forums/gener ... ieces.html
Not me.
So again google it.
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
I use Rihno's as well. I have seen them buckle once. They are safe if you make sure they are flat and the car is parked on them right. nice and light. The only thing I don't like about them is that spiders try to hide/nest in them.
rmmagow
I like this too, but can't justify it:
http://www.ezcarlift.com/ezcarlift_features.html
- 1715 Views
Last post by 98v70dad
- 18 Replies
- 3591 Views
Last post by JRev
- 18 Replies
- 2310 Views
Last post by wizechatmgr
- 1071 Views
Last post by precopster
- 2043 Views
Last post by amblerman
