I hate to ask this, I just broke a vac line in the engine compartment. I can't find the other end! I have a '91 940se with the turbo. The line is the one just below the rigid metal line on the intake manifold viewed from the passenger side of the engine. It is the small pencil sized line. I'm going back out in the heat to search for where it terminates. I also need a manual that covers this sort of thing better than the Haynes manual.
thanks,
Jack
Vac lines Topic is solved
Jack
I'll answer my own question. The line that comes off the turbo inlet that crosses over the engine has a plastic 3 way "T" where it connects to an "S" shaped hose. My "T" broke so it was hard to identify where the small vac line plugged in.
