Power On Self Test:
(1) Magnetti Marelli ETM Removed from a 2000 S80 T6 Turbo. Only four years old, so it presumably has a good bit of life left. If you're not ready to spend over $400 on a XemodeX, this is a good cheap way to keep your Volvo going if you're unsure of how long you'll own it.
Personally tested on my '99 Volvo S70 GLT Turbo, no programming necessary. It idles and drives 100% correctly, unfortunately I didn't get a video of this.
Will likely work on any 99+ Turbo Volvo that used these ETMs. Non-Turbo cars will require dealer reprogramming of the ETM. Turbo cars will treat this as a direct replacement with no programming needed.
$175 firm + actual USPS Priority shipping. A flat rate box will be used if it is deemed to be cheaper to your location.
Thank you!
