Question about S40 power brake vacuum pump
Help, Advice, Owners' Discussion and DIY Tutorials devoted to the second generation C70, S40 and V50 Volvos -- awkwardly model year 2004 ½ onwards -- plus where to go for advice and discussion on Volvo's sporty C30 Coupe powered by Volvo's ubiquitous inline 5-cylinder power plant.
rwilson1458
Year and Model: 2004 S40/ 2010 XC60
Post by rwilson1458 »
We have a 2004.5 S40 with 115K. Recently when we shut off the engine the power brake vacuum pump (Hella part number W0133-1910902) keeps running for about 2 minutes. I replaced the pump about a month ago - worked fine for about 3 weeks then started running again after engine shut off. I checked the vacuum lines leading to the pump and can't find find any obstructions or breaks. So question is, is there a relay or something else that I should check - or - maybe I just got a bad pump. Any advice would be appreciated guys.
Thanks.
