moon roof
mab20009
Check the 4 bolts that hold the glass moonroof to the rails of the opener assembly. The bolts are behind the folding plastic cover. The cover is held in by clips at the top (glass end). From inside, you can pull gently on the cover and the clips should release and the cover will fold back. You'll need a TorX screwdriver bit. Once tightened, simply press the top of cover back up under the clips.
I just did this on my 2000 S80 and now my moonroof is completely silent.
- 1868 Views
Last post by BlackThunder
- 531 Views
Last post by JDS60R
