850 Turbo will not start
Va850owner
Year and Model: 850 Turbo, 1995
Post by Va850owner »
My problem started last week after I hit a curb which popped my rear right tire.
I've looked over forums on the internet and in my haynes repair manual.
I though it could be be an electrical problem because I can hear the fuel pump buzzing. Or the fuel relay might be bad so I did jump 87 and 15. Which did not bring me any luck.
What else could cause my car to not start?
AAAWWW YYYEEAA
MoVolvos
Has thanked: 312 times
Been thanked: 525 times
Post by MoVolvos »
Not familiar with 850's but can you elaborate further? Did it quit at that moment and never started or did it progressively get worse? Does it crank but not start or does it crank at all? Have you checked for spark? Is there a Schrader Valve on the Fuel Rail to check for fuel pressure or existence of pressure etc...
charlyW
Year and Model: 97 855 T-5 CD
Post by charlyW »
Not starting Try changing the cam position sensor or crank sensor. Easter Saturday [which is a bank holiday here in the UK so no where open] my T5 decided to start playing up then decided nope it wouldn't go any further. Crank position sensors are expensive unless you're happy to get a used one. You could also do with getting the codes read off to make sure it's not something else
855 T-5 RHD Blue: MBC, Custom Map based on Rica, K&N Filter, 18T Turbocharger, White/Green injectors [depends on my mood], Blue Silicone vacuum hoses
Va850owner
Ah, I forgot to say that the car did crank. But no spark at all, and I seem to not have spark at all.
AAAWWW YYYEEAA
MoVolvos
Post by MoVolvos »
Va850owner wrote:Ah, I forgot to say that the car did crank. But no spark at all, and I seem to not have spark at all.
This link maybe helpful.
http://volvoforums.com/forum/volvo-850- ... elp-45661/
Va850owner
Would a no spark scenario be caused by a bad ignition coil?
AAAWWW YYYEEAA
MoVolvos
Post by MoVolvos »
Va850owner wrote:Would a no spark scenario be caused by a bad ignition coil?
Yes, but according to this link the Cam Sensor could be telling the ECU not to fire the Coil? I am not familiar with ignition but I am wondering if the tire incident had anything to do with it and the problem lies in that area and is fuel related. Hopefully someone else can provide some input on systematically checking for a no start. The previous link seemed to provide some good info.
http://volvospeed.com/vs_forum/topic/79 ... coil-fire/
steve850
Year and Model: XC70, 2004 and 2010
Been thanked: 3 times
Post by steve850 »
No start is either no fuel or no spark - sounds stupid to say it but true. I have a 96, so should be similar. Have you confirmed that there is gas up at the fuel rail? Look for a vavle like a tire valve and pole the pin, there should be gas. If not, i'd suspect the pump, seeing as you said this happened after a rear end incident, and the pump is in the tank. If there is no fuel, have someone turn the key while you give the gas tank a few good thumps with a rubber mallet. It may take two or three shots to get the gas up to the engine. If it starts, its the pump.
If you DO have fuel at the rail, how have you determined that there is no spark? The best way is to pull out a sparkplug, reconnect the wire, hold the base of the plug against a metal part of the engine and have someone crank it over. This will test the coil, coil wire, cap, rotor and plug wire.
Appologies if you already know all this, but sometimes best to start with the basics so we're all on the same page :-)
Steve in Montreal
2010 XC70 3.2 N/A
04 XC70 2.5T
96 850 Platinum
Va850owner
steve850 wrote:No start is either no fuel or no spark - sounds stupid to say it but true. I have a 96, so should be similar. Have you confirmed that there is gas up at the fuel rail? Look for a vavle like a tire valve and pole the pin, there should be gas. If not, i'd suspect the pump, seeing as you said this happened after a rear end incident, and the pump is in the tank. If there is no fuel, have someone turn the key while you give the gas tank a few good thumps with a rubber mallet. It may take two or three shots to get the gas up to the engine. If it starts, its the pump.
I shall try out your suggestions later tomorrow.
Thanks :D
And I'll report back on how it all worked out.
AAAWWW YYYEEAA
Va850owner
Well, I tried out both of your methods steve850, and I do have spark but the fuel rail is dry.
Is it the fuel pump?
AAAWWW YYYEEAA
