Gates has a century-long history of providing high-quality automotive products. FCP is proud to offer Gates quality parts to our Euro and Import customers, including Racing Serpentine Belts, Timing Belts, Coolant Hoses, Radiator Caps, Fuel Tank Caps, Timing Belt Tensioners, Timing Idler Pulley and various other timing components.
Gates Racing Serpentine Belts and Timing Belts
Gates Racing Performance Timing Belts are 300% stronger than stock belts and deliver up to 3 times the heat resistance; therefore, you can count on them to hold up to the rigors of high horsepower, even with interference engines. Gates belts are also precision ground, not cut, so they fit the pulley with absolute perfection, and the specially engineered adhesion layer gives Gates Racing belts an extended service life.
Gates Coolant Hoses
Gates Coolant Hoses provide exceptional durability and resistance to high pressure and heat. The premium EPDM Rubber Compound protects against the high temperatures of full throttle driving and prolongs the effectiveness of coolant because it's 10 to 15 times more resistant to water permeation than silicone hose.
For questions or to order cal Dave Greco at 1-877-634-0063 ext.227
