1993 940 Oil Light Issue
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
stereomonostereo
Year and Model: 940 1993
Post by stereomonostereo »
Hi all,
Just recently my oil light has been coming on after warmup, anytime i'm under around 1500 rpms. It would happen in the past, but only under heavy driving and would only flicker when i was at idle. I was about due for an oil change, so i changed the oil with 15w 40, but i'm still having the same issue. I'm driving a 1993 940, with 228,000 miles. I'm not noticing any difference in idling or performance, so i'm hoping it's a sensor issue. Can anyone point me in the right direction of what to look at next? Thanks in advance!
JDS60R
Been thanked: 3 times
Post by JDS60R »
Test the oil pressure and compare it to spec. Or replace the oil sensor and see if it still comes on. Most likely you have an o ring failure on the oil pick up or your oil pump may need replacement. I don't do as much work on 940's 240's anymore so I will hope others chime in
Retired
stereomonostereo
Thanks for the repsonse. I ordered a replacement oil pressure switch, and i'm going to install that tomorrow and see what happens. If that doesn't take care of the problem, then i'm thinking oil pump.
stereomonostereo
It turns out that it was the oil pressure switch. I'm happy to not be spending the holiday weekend doing an oil pump. Thanks again!
