760 GLE V6 Air con tweak
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
tblo760
Year and Model: 760 GLE 1987
Post by tblo760 »
Pressure switch.jpg (84.38 KiB) Viewed 516 times
After 25 years I've never had a major problem with this car (exept for a speeding ticket)Recently the air con started to work intermitantly.Knowing that there were no leaks I decided to recharge the system,every thing went ok,but the issue still existed.So, as the pressure was ok and the clutch and drive belt etc; checked out, the only thing it could be was that the pressure switch was at fault. I had a spare switch,but replacement would mean the loss of all gas,so I decided to save it till the next re-gas.The pressure switch is adjusable and a 1/4 turn anti-clockwise solved the problem.If you do this adjustment, do NOT back off too far,just enough to kick the clutch in,this is because you do not want the clutch to engage on too low a pressure.
The way of the wicked is as darkness,they know not at what they stumble,(That's why I'm here to help)
