Hello all
My 1994 washer pump has died, at least it is very noisy and barely gives a trickle.
I notice it is attached to the side of the reservoir, do you know how it is attached?
Also is it the same for wagons as sedans?
Thanks
Matt
1994 855 turbo auto
Windscreen washer pump.
Free2drive!
- Year and Model: 2007 XC90
jimmy57
- Been thanked: 320 times
The washer pump pops into a recess and there is a grommet where end of pump inserts into tank.
Wagon and sedan share reservoirs but sedan does not have the hole punched and grommet inserted for second pump.
Before you commit to a pump try taking hose off the pump and seeing if it pumps heartily then. If the pump output is obstructed it will be noisy.
ronaldo2526
- Year and Model: 850 Turbo 1996
Had a similar problem. For me it turned out that it was the check valve in the hose that splits the flow to the two jets. Don't know if this helps you.
