have codes, unsure what they mean?
1996 - 2004 S40
1996 - 2004 V40
dejavu33
Year and Model: 2002 S40 turbo
Post by dejavu33 »
ok bare with me! not sure if i have what I need to figure out the check engine light being on? We plugged into a code reading device and this is what it gave me (keep in mind it was one a friend had) lol! so the code was P0420 generic and when I plugged that into the computer at home on thecanobd2.com repair solution it said = Three way catalytic converter efficiency power deterioration... can anyone explain this in plain english please! I am a mother of two who just needs the basics of what to do next and how bad is it!! thanks a billion.
zulu-v40
Year and Model: 2003 V40
Post by zulu-v40 »
When this happened to me, it was a clogged, defective catalytic converter, but it can mean a lot of different things. This code is tricky to track down. There are oxygen sensors connected to the catalytic converter. These could be faulty too. It could also mean you have vacuum leaks. It could mean the engine coolant temperature sensor is faulty. Are you using unleaded fuel, 91 or higher? How many miles are on the car? Before throwing parts and money at it, I would remove the catalytic converter and inspect. Is it clogged?
2003 V40 T4, silicone vacuum hoses, K&N air filter, iPd Boost Gauge, iPd HD TCV, PowerSlot Rotors
