2002 S60 A/C vibration when on Auto
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
Syrix
Year and Model: S60 2002
Post by Syrix »
Hi, this just started yesterday in my Volvo. I got in and cranked it up then put the A/C on auto. Like usual it goes into high mode because the car had been sitting all day in the sun. The steering wheel starts vibrating and I can hear a "vibrating" sound from the passenger side around the floor board. It continues like this when I drive. I put the A/C on lower, like around medium, and it stops. The air is still nice and cool.
Is there anything I could check or could this be the start of something with my A/C? Thanks!
jimmy57
Been thanked: 320 times
Post by jimmy57 »
Sounds like your fan is out of balance. It could have something that got in from under the dash or from the air inlet under cowl. The air filter may have dropped a piece into it.
Syrix
Post by Syrix »
Thanks, I will check this out.
jimmy57
Post by jimmy57 »
Edit: Not possible for air filter to have lost a piece as the filter is down stream on P2's. Still possible for other things to get into blower wheel.
Syrix
Post by Syrix »
Where can I find the blower wheel?
fazool
Year and Model: S60, 2007
Been thanked: 7 times
Post by fazool »
I concur its your HVAC blower motor.
Its likely a bearing thats worn out.
I understand its quite a project to remove that blower but the repair of the bearing is rather easy.
2007 S60 2.5T AWD (Daily Driver)
2001 S60 2.4T (Daughter's Car)
2003 S80 2.9 (Son's Car)
1995 850 2.4 (Daughter's Car - sold off)
2005 S40 2.4i (Bought new - since sold)
1986 740GLE 2.3(First Volvo - sold off)
DGM
Year and Model: V70 2.4i 2005
Been thanked: 3 times
Post by DGM »
Syrix wrote:Where can I find the blower wheel?
Here is a DIY on how to remove it. Have a look at it first. Two of the 5 screws that maintain the blower fan in place are hard to install. Some leave them out and the motor assembly can wobble. Also look for any obstructions.
Blower motor repair
The motor is pretty much sealed. The wheel is coming with the motor as one assembly.
http://www.fcpeuro.com/products/volvo-h ... 90-9171479
I opened one recently to investigate. At high mileage brushes get worn out. It is not built to be opened.
V70 2005 2.4i 195,000km, sold
S70 1998 T5 355,000km, sold
960 1994 80,000km, sold
760 1990 Turbo 265,000km, sold
Benjie
Year and Model: 2003
Post by Benjie »
I have this exact same issue that started yesterday in my 2003 XC70 with 190K on it. Did you fix this and or what was the cause?
Benjie Edmonson
Photographer
Ben Edmonson PHOTO
www.benedmonsonPHOTO.com
Sent from my iPad using Tapatalk HD
