99 XC AWD Overheating??
Perplexing problem with my 1999 V70 XC/AWD. Last summer intermitently the outside tempeture gauge would read higher than actual outside temp. The temp would seem to increase during heavy traffic. At about 95-100 degrees the AC would shut-off and then the actual temp gauge would start to rise. I flushed the system and cleaned the radiator seemingly problem sovled. Through the fall, winter and spring it drove fine. Well its back doing the same thing now that the weather is warm again. Any suggestions on where I should start to diagnose this would be greatly appreciated. Thanks!
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
There is a difference between the ambiant "outside temp" gauge that tells you how hot it is outside and the motor temp gauge that tells you how warm the motor is.
The ambiant temp gauges means nothing to the operation of the car. It's just a friendly notice to let you know how hot or cold it is outside in case you are very comfy inside the car. The sensor is under the car in the lower front section of the air scoop. So, when you are in traffic and driving very slow, the heat from the road, motor, etc., will cause the reading to raise, because it's telling you how hot it is under the car. Don't worry about that. If your ac wasn't cooling the car well, it likely needs serviced but to be honest with you, Volvo's ac system are not the greatest and don't do well over 95 degrees. It's just to hot.
Now on the other hand, if you are seeing your engine temp needle rise, let us know.
- rspi
Contact rspi..
What starts to overheat?
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
Outside Temp Reading is just a Thermometer which measures the Ambient (Outside Air) Temperature
The 2 are not related but it so happens at this time the Coolant Needle is going up when the Outside Air Temp is 100+ Degrees which makes sense as your car has a problem when it get hot. If you have your AC on the Radiator Cooling Fans stay on till the AC shuts off. This is why your Radiator (Coolant) Temp does not go up when the AC is on.
Although your Coolant is pretty fresh the Thermostat maybe stuck partially open so only when the weather is hotter the Coolant Temp Needle Rises.
Are you losing Coolant anywhere?
The Engine (Coolant) Temp Gauge with Needle is the measure of Coolant Temp in the Enginetwncty wrote:The engine temp gauge starts to go up after the outside gauge reads 100+ degrees.
No loss of coolant. I am replacing the thermostat tonight. Next couple days are going to be 90+ degrees. I'll see if that works. I have a ODBII that shows the cars temp at idle after a short drive around the block and 10 mins of idle to be 199 degrees. I don't know if that is normal or not. My only reference to the outside temp gauge is that tonight as an example; outside tempature is 73 degrees driveway ground is cool but when I start my car and let the engine idle the outside temp gauge raises in tempature. In this case it registered to 90 degrees before I shut the car off.
- MoVolvos
When you begin to drive the Temp should come down a little bit as the heat trapped under the vehicle can raise the Air Temp Gauge. Hope the Thermostat works!twncty wrote:No loss of coolant. I am replacing the thermostat tonight. Next couple days are going to be 90+ degrees. I'll see if that works. I have a ODBII that shows the cars temp at idle after a short drive around the block and 10 mins of idle to be 199 degrees. I don't know if that is normal or not. My only reference to the outside temp gauge is that tonight as an example; outside tempature is 73 degrees driveway ground is cool but when I start my car and let the engine idle the outside temp gauge raises in tempature. In this case it registered to 90 degrees before I shut the car off.
Here is some additional information:
How To Fix An Overheating Car (The Long and Short of it)
He actually answers emails! Albeit, in a week or so.
... re=related
- MoVolvos
There are several Temp Range Thermostats so the 199 Degrees is normaltwncty wrote: I have a ODBII that shows the cars temp at idle after a short drive around the block and 10 mins of idle to be 199 degrees.
http://www.oreillyauto.com/site/c/searc ... vi=1434025
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
Your car is fine - don't worry about it. They all do this. I've seen 135 on my S70 before.
The engines operate between 180-220 degrees, which is indicated at the 3:00 position on the dash temp gauge.
The ambient temp sensor is located close to the radiator and picks up heat from that area. The asphalt on the road and the layer of air within a few inches of it CAN actually be 110+ degrees in the summer heat, so that affects it as well.
A bit of preventative maintenance, if you have not, would be to change coolant, flush radiator, and replace all coolant hoses on your car (turbo ones included!). Summer temps are very hard on your car's cooling system, and these hoses will burst in hot weather if they are old.
'98 S70 T5
2016 Chevy Cruze Premier
- 1381 Views
Last post by precopster
- 30 Replies
- 9054 Views
Last post by erikv11
- 1332 Views
Last post by cynlim
- 972 Views
- 1798 Views
Last post by Kfbtaz
