1998 FWD s70 w/o turbo, transmission question
How to go faster, stop quicker, and turn harder. Chips, exhaust, larger turbos, bigger/slotted/drilled rotors, high performance brake pads, manual boost controllers, performance shocks/struts/springs, airbox mods and more! Also discussion on HID and Xenon lights, aftermarket foglights and other exterior lighting.
doofygy1987
Year and Model: 1998 S70
Post by doofygy1987 »
what is the difference between a transmission assembly for a turbo and a non-turbo 1998 s70?
why I ask. I may be able to come into an s70 for next to nothing and it has some transmission issues. I am trying to calculate the cost of a worst case scenario (replacement) and the only remanufactured/used trannys i can find are for turbo FWD s70s.
any info would be helpful
JordanW
Year and Model: 96 850R
Post by JordanW »
Auto trans or manual trans?
As for the auto, the only difference between the turbo and N/A autos is the final drive ratio; however people have used them interchangably. You should be able to pick up a used auto trans for around $350 depending on mileage.
96 850R = ARD Green m4.4, rip, Kilen's, C70vert subframe, S60R exhaust manifold, NA TB with 960 plate, SNAAB J pipe, MSD coil.
jimmy57
Been thanked: 320 times
Post by jimmy57 »
The final drive ratio is different as mentioned and the TCM for the NA engine with a turbo gearbox will set codes (wrong gear ratio code) due to that.
The ratio is numerically lower and will make a NA engined car a real slug in acceleration. You can swap the TCM from a turbo car but your shift points will always be too soon (shifts early) as the turbo ECM is expecting a higher torque signal from ECM and the mapping in software for shifts will shift it too soon as a result. It may even set codes due to seeing too high throttle opening with too low of a torque signal.
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 19 times
Post by jblackburn »
A transmission from a NA 96-97 850 will work just as well as a 98 if that increases your odds of finding one.
'98 S70 T5
2016 Chevy Cruze Premier
