1999 V70
Forum rules
Please create one topic per Volvo you own. Then simply post to that topic when you maintain or repair your Volvo. You'll have a nice record of what you did, when, and how much it cost. Only you can post in your topic.
alastair01
- Year and Model: 1999 V70
1999 V70
I have been chasing down a mystery of disappearing coolant fluid. Replaced cracked coolant tank and sensor which fixed leak. Now fluid not leaking but disappearing. Compression good and plugs look clean. No leaks on hoses or radiator. Dry carpets and no smell of antifreeze in car. Pulled back carpet and exposed heater core. It's leaking! fluid is all under the carpet trapped under the rubber backing. Mystery solved, ordered parts from FCP Groton and will replace tomorrow!
