91' 240 no start again ??clogged injector??
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
greenmandave
Year and Model: 240, GL, Estate '91
Post by greenmandave »
hi all
my beloved broke down again :(
i broke down about a month ago and figured it was the main fuel pump
next day broke down 15 miles later ((in the same place funnily enough))
and realised the in-tank pump had gone
while removing the sender unit i snapped the return arm so just replaced it
and she wont start
both pumps are definitely running correctly and a new filter was done recently too
there is a lot of pressure in the fuel rail and petrol is leaking between the rail and the fuel pressure regulator
could this be caused by clogged injectors or is it an electrical problem ?????
or is the fuel pressure regulator clogged/broken???
any help deeply appreciated
thanks DAVE
