While changing the front struts the right drive shaft came apart. Reason: the ball joint came apart (Balls in the housing - shart shaft disconnected)
I have ordered but I'm not in the possesion yet of a repair manual/cd.
Questions:
1. Is it possible to re-install the ball bearing? And how?
2. If not, which part do I need to order? a. the full right drive shaft? b. left and right drive shafts? or c. the "fixed part" of the long right hand drive shaft ?
Since the car already did 200K KM's some wear might be expected. Right?
Thanks for the advice and best regards,
Marcel
