97 850 GLT no power to fuel pump
andrew135
Year and Model: 2002 V70
Post by andrew135 »
Need Help, I replaced my failed fuel pump,went to start the car when turning the ignition to position II I did not hear the pump start.So then I assumed it was the fuel relay so I replaced it with a new one and still no power to the pump.The 15 amp fuel pump fuse is not blown. What else could be wrong, Thanks Andrew
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
Have you checked fuel pressure at the rail? Did you check for power with a volt meter at the pump? Sometimes I don't hear the pump until I release the key after I try to start it.
andrew135
Post by andrew135 »
Hi, I checked the plug back at the pump and no voltage, I also jumper terminals 15 and 87 at the fuel relay and still nothing.I hooked the new fuel pump directly up to a battery and it works fine,the car will run fine untill the fuel pressure drops.
