oil leaking upper right rear of engine (98 v70 )
redhorse2000
Year and Model: v70,1998
Post by redhorse2000 »
when viewing from underneaht the steady drip drip comes from upper right rear area of engine. Cannot see from air box area have been tring to find and enginebreakdown veiw to better undestand what is there that could leak oil before removing any items unnecessary.Would like to repair myself. Any suggestions
Has thanked: 292 times
Been thanked: 765 times
Post by erikv11 »
Technically the upper right rear of the engine is the corner closest to the battery. But I think you mean none of the corners near the firewall? Which side, driver's or passenger's?
A picture of the area with the leak would go a long way for getting suggestions. Hopefully a moderator will move this to the maintenance section, you will get more replies there.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
obayha
Year and Model: V70 1999 Base
Been thanked: 2 times
Post by obayha »
I'll take a stab and say the cam seals. If on rear upper, close to air box, that is my guess. The rear ones are not to bad of a repair.
Could also be plugged PCV system pumping oil out and looking like it's coming from that area.
Pictures will help.
What part of NC you in?
1998 V70 T5 331,000 :( Her last day was on 3 cylinders.
New to me 1999 V70 NA 163,000 Now at 217,000
2006 V70 2.5T in driveway (WIFE'S)
1982 Toyota FJ40 Land Cruiser
JeffersV70
Year and Model: 1998 V70
Post by JeffersV70 »
Sounds like you might be referring to the rear exhaust camshaft. The seal is in behind the camshaft sensor. Either pop off the camshaft sensor and check for any oil behind it or use a mirror to look at the weep hole on the bottom of the sensor. I believe a leak here will drip down onto the transmission and down the back of the transmission. Also check the rear intake camshaft seal, which is behind the distributor cap and rotor. When this seal went on my '98 V70 N/A I would occasionally get rough idling, lack of power, and all kinds of misfire codes. I was able to purchase the seal at a local Napa for around $4.50, and it may have taken 30-45 minutes to change out. If you've blown a seal, double check your crankcase for any pressure at the oil dip tube, you don't want to lose your RMS next!
1998 V70 N/A / Red / 127k
1998 V70 N/A / Black / 109k
Post by erikv11 »
Also is your car a turbo or non-turbo?
'06 S60 R, 197k
redhorse2000
could this be the cam bank seal?
Year and Model: 2004 V70 2.5T
Been thanked: 466 times
Post by cn90 »
If you want help, post a picture(s).
Cannot help w/o picture(s).
vjaneczko
Year and Model: 2006 S60R
Been thanked: 6 times
Post by vjaneczko »
cn90 wrote:If you want help, post a picture(s).
+1 - it would help a lot.
But from what you mention, it does sound like a cam seal. There are a few other things that it could be, but a pic would help isolate the problem. If you pull the airbox out (easy to do), you'll probably get a better view of the back-side of the engine. If you have a turbo, you'll also have a few intercooler hoses to deal with but they are also easy to remove.
One suggestion is to get a can of engine cleaner and scrub it clean, then drive it around for a day or two (checking your oil level, of course). That will make it easier to spot where the oil is coming from.
1997 855 GLT - R.I.P.
2006 S60R - For ME!
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
First of all, welcome to the forum.
What everyone is trying to say is that most oil leaks in these cars are caused by a blocked PCV system that hasn't been serviced or changed lately.
Then, a clogged PCV system will usually cause cam seals and crank (RMS) leaks. So, change the PCV system if it hasn't been serviced lately and then change the seals that are blown or missing.
Post by cn90 »
I am replacing the REAR Cam seals this weekend (using SKF 11809 OEM seal) and will post some quick DIY.
