2001 xc 70 won't start
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
dvo
Year and Model: v70 xc 2001
Post by dvo »
I have a 2001 xc70 turbo that will not start. My wife was driving and it just quit running. :(
While trying to start it would run for about a second and stop this happened about 5 times. After getting it back to the house I changed the fuel filter, checked the fuse and swapped the relay with the one for the fog lights, still no start. :x Pulled the cap from the fuel rail and fuel runs out when the key is turned on but does not spray like I would expect. I think the fuel pump is ok or I wouldn't have fuel at the fuel rail, am I correct in this thinking? Right now I am at a loss as to what else it could be. Any one have a thought on this? :?:
igel513
Year and Model: 2003 S60 T5
Has thanked: 1 time
Post by igel513 »
Is there a CEL or DTC. If it does, have it scanned by your local parts store then post here. The experts will then chime in. How many miles on odo.? Its a weekend so they're having fun somewhere.
dvo
Post by dvo »
There is no codes. the car has 122000 miles, the timing belt was changes at 114000 miles and the ETM was cleaned then also.
marcusheard
Year and Model: S70 turbo, 1998
Post by marcusheard »
What about the ICM (ignition control module) are you getting spark?
dvo
Post by dvo »
I have not checked for spark as it did start and try to run for about a second each time I tried. I will do that today.
dvo
Post by dvo »
checked and it has spark. :D New problem.... the rear hatch will not latch. :( Car is getting seriously close to the scrap yard. :evil:
dvo
Post by dvo »
Decided it is time for it to go. :(
Put it for sale hope someone will be able to fix the problem and enjoy it for a long time as I have. :)
precopster
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
Wow!! Forum members here have held on to cars and sorted them with far more problems than this.
Have you checked the fuel pressure properly? It should squirt out at the rail with great velocity. The fuel pump's regulator may be needed. I think with this model it's built in to the pump but you could purchase an aftermarket one inexpensively.
Don't give up yet. With no codes showing it's likely something relatively simple.
Rear hatch may require a fully charged battery. With all that cranking voltage is likely quite low now.
Sent from my GT-I9100T using Tapatalk 2
marcusheard
Sounds like a fuel regulator issue: here is a youtube video from a guy with a volvo displaying the same problem
dvo
Post by dvo »
I live in a remote area so getting parts from a dealer is quite an ordeal. :(
I don't have a garage, necessary tools or a decent area to work on a vehicle that is why I decided to sell it. :?
If any one on the forum is interested in purchasing it I have a price of $4500.00 dollars on it, just let me know. :D
