1987 740 drive belts being replaced.
When I removed the three (3) belts, I observed that the A/C Compressor belt was routed to the front pulley (of three) on the crankshaft which is out of line by a pulley width with the pulley on the A/C compressor. The belt has never come off, but it doesn't seem as though this is right.
Here's what I've got:
Crankshaft--3 pulleys
water pump--2 pulleys
power steering pump--1 pulley
alternator--2 pulleys
A/C compressor--2 pulleys
All rear pulleys in line.
Belt 1: rear crankshaft pulley=rear water pump pulley=power steering pump
Belt 2: middle crankshaft pulley=front alternator pulley
Belt 3: front crankshaft pulley=front A/C compressor pulley
It's Belt 3 that's the problem.
Routing should be---???
Thanks,
Charles
740 belt routing
lummert
- Year and Model: 760 1988
- Been thanked: 26 times
Are all of the belts off by one space? If not, check the A/C compressor rubber mounting bushings. If yes, check the crankshaft pulley for slipping. Make certain that you're trying to install the A/C belt on the correct groove on the compressor pulley, I had an alternator belt on the wrong alternator pulley groove and it wore out the belt.
1988 Volvo 760 Turbo Wagon
No, the only belt that's off by one space is the A/C compressor.
Rubber Mounting Bushings of the A/C compressor all (4 of them) are sticking out of their metal housings to the rear for some reason, and it seems, by the 1/2" I need to get the front A/C pulley aligned with the crankshaft pulley.
HOWEVER, if I move the compressor toward the front, it looks as though the brackets for the adjustment of the belt will be misaligned.
Any insight?
Thanks--
Any insight?
Thanks--
lummert
I'm thinking that the adjustment brackets will move forward with the compressor. Of course I would have to check my 88 765 to make certain. My bushings are worn enough that the compressor moved around too much. I learned of the worn mounting bushings when I recently decided to replace the broken adjuster after driving the car more than 6 years without the belt. After 6 years without using the A/C compressor (and no belt installed) the clutch is stuck and won't release.
- 4796 Views
Last post by Salomons Driveway
- 1752 Views
Last post by mika
