Dearest volvoers:
I am now coming at you with yet another little fidgety problem: My alarm system quit (in gradual steps).
I will describe as detailed as possible the sequence of events:
1) My alarm was working fine until...
2) Suddenly one day the remote wouldn't work. I reprogrammed it (turning the key on and off 5 times and following that whole procedure) and it worked again.
3) Step 2) repeated itself a couple of times.
4) After a while, even though I would be able to get the alarm to reprogram itself (with the 5-time-key-turning procedure), it wouldn't "remember" the remotes.
5) A few days ago I tried to reprogram once again but now the alarm is simply dead. The procedure for reprogramming it doesn't work and the LED is not even blinking.
I am assuming I have a dead alarm control unit (121 and 122 under the steering wheel assy. - or something like that).
I am at this point open to other suggestions. I am leaning towards changing the alarm control unit. What do you guys think? Any other ideas/things to check for?
Thanks a billion!
FinnoSwede
1996 Volvo 850 Alarm system died
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Sounds to me like you have it figured out. Either that control unit or a relay.
FinnoSwede
- Year and Model: 850, 1996
Hi! Thanks for the reply. What relays should I look for, and where are they?rspi wrote:Sounds to me like you have it figured out. Either that control unit or a relay.
Thanks!
FinnoSwede
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
Download the wiring diagrams for your car from here:
https://www.matthewsvolvosite.com/volvo-wiring-diagrams/
You'll find full diagrams and pictoral component locations.
- 4771 Views
- 3954 Views
Last post by ZootAllures
- 1887 Views
Last post by jonesg
- 2192 Views
Last post by Sailsman
- 1999 Views
Last post by PeteB
